64CTRL and Logic Pro
I am trying to use 64CTRL and Logic Pro.
I can control VST Plugin on Logic Pro and it seems that it is receiving Midi info back from Logic but if I adjust any parameter on screen, it make the the jump when making adjustment from EN16.
Is there anyway to fix this.
Also is it possible to use 14bit midi on 64CTRL?
Chaki
Yes, all of this could be possible but would require retrofitting the 64CTRL with these features.
For now the offshoot version called 256CTRL has bi-directional MIDI if that’s what you want.
14bit MIDI will take time for me to implement. Soontm?
Dear Narayan,
Thank you, for reply.
I am happy to have bidirectional to start with.
I will try 256CTRL.
I will wait patiently for 14bit.
Chaki
I just tried 256CTRL+MidiRX+Color.
Somehow bidirectional does not happen.
Do I need to modify some setting?
Chaki
I just checked too and it seems that the currently uploaded version of 256CTRL does not support bi-directional MIDI.
This is probably a mistake, so I made a quick fork and patched in the bi-directional MIDI capability. You can find the patched profile under 256CTRL - MIDIRX Fix temporarily until EchoMatter fixes his version.
