Ableton disconnecting/dropping Grid
Hello All, I am sure this has been discussed already, and probably on the Discord group that I am not on at present. That said, any help would be appreciated:
Using Windows 10. In the past, my Grid devices would disconnect from Ableton during my live sets. Lately, it’s happening ALL the time and it’s a serious problem for my performances. I’ve done these things: 1. update the firmware (always), 2. in Windows Device Manager I ensure that the power is never turned off on my USB connections, 3. I have all the boxes checked for Intech in the Ableton MIDI preferences (both in and out). What’s going on here?! My other USB peripherals do not get
What are the bootloader versions on the modules?
What is their name when you connect them in “removable device mode” to the computer?
It can be that they require a bootloader update if you haven’t done it already:
https://docs.intech.studio/guides/troubleshooting/bootloader
When a module disconnect happens, you need to plug out and in the connected module to get back up?
@PHINYX hey !
Had same issue on Mac
Updating the bootload and firmware solved the usb problem here,
but @kertikristof now i have some bugs on the grid editor and value parameter
Is it apparent after a module clear?
I’m not sure if there was any breaking changes with module configurations since the bootloader update - can be a corrupt config causing issues on the module.
it started when i updated bootloader, dont know much more.
I reinstalled the GRID software, but it keeps acting weird, there is a way to do a complete clean software reset of my EF44 ?
@kertikristof I found the issue.
Upgrading the EF44 firmware to latest version ( 1.2.28 ) it creates an issue where faders act weird and without control,
Downgrading firmware to 1.2.27 everything works fine.
Firmware 1.2.29 fixed the value problem!
