Anything coming in the future for tempo sync?
I’ve been messing around trying to make some tempo aware features and it requires a fair bit of scaffolding to calculate the pulses, and it mostly works. But I’m wondering if maybe the Intech gods would consider some system functions like:
system_bpm() — returns current BPM (float or integer)
system_period() — returns ms per quarter note (float or integer)
clock_phase() for phase within a beat if we want to be fancy
Scanning for the specific midi message and doing the calculations for bpm in the timer + system takes up a fair bit of space. It would be super nice to be able to grab it organically and make tempo driven cc ratchets, lfos, or pulse leds in time etc.
Any boilerplate bpm code that somebody wants to share, maybe I’m overcomplicating it?
There is some kind of timer parameter that lets you sync to clock easier, called Timer Source.
You can find a really old demo for it in the Cloud called MIDI Sync Demo XXXX.
Every part of the config that counts can be found under System Setup.
The above only lets you sync to MIDI clock, not really react to it…
Was there any progress here ? Still struggling to sync. thanks
Hi, AFAIK receiving clock on Grid as a whole is broken at the moment, and has been broken since we switched from the legacy MIDIRX system to the current callback one.
