BU16 one side not working
I purchased and just received a BU16 and an EF4 module, I’m just starting to learn it, I was connecting these to my DAW (Reaper) and it’s generally working.
But I found that one side of the BU16 seems to not be working. When I have the EF4 attached via USB-C and try to mate the BU16 to it, all but one side of the BU16 connects. I’ve tested this visually using the software too.
I haven’t done much testing so can’t describe much more yet, but I’ll test more tonight and post a follow-up. But I’m curious what’s the support policy/procedure on this? I just received and opened the boxes for these yesterday, never used.
Thank you
Are you the same user that wrote to us over mail as well?
If so, there you said you had to wait a bit more and the BU16 connected after that on that side as well. IF this issue is solved, please get back to us here as well, thank you.
