I’m a new user and I have the BU16 module which I use as controller for the shortcuts of my DAW (Cubase 12). I want to ask you if it is possible to assign two different actions, one for the first push of the button and a different one for the second?
For example:
the first time that I push the button I enable the fuction “Read” of a selected track in my DAW
the second time instead, I enable the fuction “Write” of that selected track.
Also new user here. This can be done with Lua code. I would use a variable that toggles, e.g. in the press event, if toggle == 0 then toggle = 1 elseif toggle == 1 then toggle = 0 end. This will cause a flip from 0 to 1 or 1 to 0 on each press. Then depending on the value send different midi. Initialize toggle variable in the init event.
The toggle if statement could be done with a logic operation, but that would be less clear as description here. Usual disclaimers apply …
