Can't login into this forum using Safari on macOS
Hi All, it’s all in the subject. If I try login using Safari for macOS I get in some kind of loop between the login form and the Cloudflare screen checking that I’m human. I’ve tried this also in a ‘private’ window without any cookies stored or extensions running. I’m forced to use Chrome. Thanks!
I am on a Windows PC and have had the same type of login problems. I tried different browsers, resetting the password, creating a new account, and everything else I could think of, but kept getting blocked out. Now I find I can login some of the time, but other times I am stuck in the same loop as you. I have never been able to see any difference between the times it works and the times it blocks me out, other than I am trying at different times or on different days. It seems to me like a host problem, since I change nothing between attempts and sometimes I am in, other times not. I have “solved” this by simply trying again later when it initially does not work.
Hi, just to bring this up again: I also have problems accessing this discourse based forum because of the Cloudflare deadlock.
It’s (obviously) OK on Windows or on Chrome on the macOS side - However, I’ve not been able on my iPad at all. Safari is not OK.
Maybe someone can check - this seems to be a known problem on discourse, and other discourse based communities are OK :innocent:
