I think I need to use Encoder Mode (Relative 2’s comp) so that turning knob does not make jump in Logic Pro.
My question is, Do I need to place EC Encoder Mode in every encoder elements?
It seem to exceed the max script length doing this way.
Chaki
Chaki
I am using 64CTRL. I guess this is taking up most of script length.
If I can change Page independently for EN16, I would be very happy.
64CTRL will misbehave if you try to adjust messages in the way you said above.
Modifications outside of those described in the descriptions of the profile might introduce unintended behavior.
