Eratic behavior with two modules
I get erratic behavior from my two grid controllers when I connect them together to the computer or my Midi Interface (it also accepts USB Midi Devices). Sometimes the second module (the one without cable and just magnetically connected) doesn’t appear in the grid editor at all, sometimes it does not load all features (e.g. not all lights work and not all midi is sent). Both of the modules alone work without any problem, but together it is a mess and totally unreliable. What could be the reason for this behavior? It does not seem to be a power problem, as I tried it on USB ports that load an iPad or Laptop. But something is wrong with the way it is programmed.
I am not really sure how to share the code here, as I cannot attach any downloads … and uploading via cloud does not seem to work for me.
    "id": "46aee002-731e-4b22-b097-60c421384f05",
    "modifiedAt": "2024-04-05T02:06:54.915Z",
    "name": "Cubase Controller EF44 coded",
    "description": "Click here to add description",
    "type": "EF44",
    "version": {
        "major": "1",
        "minor": "2",
        "patch": "51"
    "configType": "profile",
    "configs": [
            "controlElementNumber": 0,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] self:emo(2) self:ev0(90) self:bmo(1) self:bmi(0)self:bma(1) glc(0,1,255,0,0,0) glp(0,1,1) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] if self:bva()==0 then bank=1;glc(4,1,0,255,0,0)glc(5,1,255,214,0,0)glc(6,1,255,0,0,0)glc(7,1,255,104,0,0)elseif self:bva()==1 then bank=2;glc(4,1,255,218,0,0)glc(5,1,0,255,228,0)glc(6,1,0,0,255,0)glc(7,1,255,0,180,0)end;glp(0,1,self:bva()*127) ?>"
                    "event": 2,
                    "config": "<?lua --[[@cb]] local val,Enc1cc=self:eva(),12 if bank==1 then Enc1cc=12 elseif bank==2 then Enc1cc=16 end gms(0,176,Enc1cc,val) ?>"
                    "event": 6,
                    "config": "<?lua  ?>"
            "controlElementNumber": 1,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] self:emo(2) self:ev0(90) self:bmo(1) self:bmi(0)self:bma(1) self.enc1cc=13 glc(1,1,0,190,255,1) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] if self:bst()>0 then gms(0,144,0,127) else gms(0,144,0,0) end ?>"
                    "event": 2,
                    "config": "<?lua --[[@cb]] local val,Enc1cc=self:eva(),12 if bank==1 then Enc2cc=13 elseif bank==2 then Enc2cc=17 end gms(0,176,Enc2cc,val) ?>"
                    "event": 6,
            "controlElementNumber": 2,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] self:emo(2) self:ev0(90) self:bmo(1) self:bmi(0)self:bma(1) self.enc1cc=14 glc(2,1,255,204,0,1) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] if self:bst()>0 then gms(0,144,1,127) else gms(0,144,1,0) end ?>"
                    "event": 2,
                    "config": "<?lua --[[@cb]] local val,Enc1cc=self:eva(),12 if bank==1 then Enc3cc=14 elseif bank==2 then Enc3cc=18 end gms(0,176,Enc3cc,val) ?>"
                    "event": 6,
            "controlElementNumber": 3,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] self:emo(2) self:ev0(90) self:bmo(1) self:bmi(0)self:bma(1) self.enc1cc=15 glc(3,1,255,8,26,1) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] if self:bst()>0 then gms(0,144,2,127) else gms(0,144,2,0) end ?>"
                    "event": 2,
                    "config": "<?lua --[[@cb]] local val,Enc1cc=self:eva(),15 if bank==1 then Enc4cc=15 elseif bank==2 then Enc4cc=19 end gms(0,176,Enc4cc,val) ?>"
                    "event": 6,
            "controlElementNumber": 4,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] local val=self:pva() glc(4,1,102,255,0,0) glp(4,1,val) ?>"
                    "event": 1,
                    "config": "<?lua --[[@cb]] local val,Fad1cc=self:pva(),4 if bank==1 then Fad1cc=4 elseif bank==2 then Fad1cc=5 end gms(ch,176,Fad1cc,val) glp(4,1,val) ?>"
                    "event": 6,
            "controlElementNumber": 5,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] local val=self:pva() glc(5,1,255,214,0,0) glp(5,1,val+1) ?>"
                    "event": 1,
                    "config": "<?lua --[[@cb]] local val,Fad1cc=self:pva(),4 if bank==1 then Fad2cc=3 elseif bank==2 then Fad2cc=6 end gms(0,176,Fad2cc,val) glp(5,1,val) ?>"
                    "event": 6,
            "controlElementNumber": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] local val=self:pva() glc(6,1,255,0,0,0) glp(6,1,val+1) ?>"
                    "event": 1,
                    "config": "<?lua --[[@cb]] local val,Fad3cc=self:pva(),11 if bank==1 then Fad3cc=11 elseif bank==2 then Fad3cc=7 end gms(0,176,Fad3cc,val) glp(6,1,val) ?>"
                    "event": 6,
            "controlElementNumber": 7,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] local val=self:pva() glc(7,1,255,104,0,0) glp(7,1,val+1) ?>"
                    "event": 1,
                    "config": "<?lua --[[@cb]] local val,Fad4cc=self:pva(),1 if bank==1 then Fad4cc=1 elseif bank==2 then Fad4cc=8 end gms(0,176,Fad4cc,val) glp(7,1,val) ?>"
                    "event": 6,
            "controlElementNumber": 255,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] bank=1 ?>"
                    "event": 4,
                    "config": "<?lua --[[@cb]] gpl(gpn()) ?>"
                    "event": 5,
                    "config": "<?lua --[[@cb]] local ch,cmd,par1,par2,i=midi.ch,midi.cmd,midi.p1,midi.p2,1 if cmd==144 or 128 then if par1==0 then glp(1,1,par2)elseif par1==1 then glp(2,1,par2)elseif par1==2 then glp(3,1,par2)end end ?>"
                    "event": 6,
    "cloudId": "sR8hapOJtkCuiHShYsum",
    "owner": "QGKFloLWcfdWzJMxSnlTdTyAyFl2"
    "id": "90e08a69-1063-46ef-9e06-02891eebac97",
    "modifiedAt": "2024-04-05T02:16:45.250Z",
    "name": "Cubase Controller BU16 coded",
    "type": "BU16",
    "version": {
        "major": "1",
        "minor": "2",
        "patch": "51"
    "configs": [
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(0,1,0,0,255,0) glp(0,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,12,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
                    "config": "<?lua --[[@cb]] print('tick') ?>"
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(1,1,0,0,255,0) glp(1,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,13,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(2,1,0,0,255,0) glp(2,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,14,val) glp(num,1,val) toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(3,1,0,0,255,0) glp(3,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,15,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(4,1,0,0,255,0) glp(4,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,8,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(5,1,0,0,255,0) glp(5,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,9,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(6,1,0,0,255,0) glp(6,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,10,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(7,1,0,0,255,0) glp(7,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,11,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
            "controlElementNumber": 8,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(8,1,0,0,255,0) glp(8,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,4,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
            "controlElementNumber": 9,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(9,1,0,0,255,0) glp(9,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,5,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
            "controlElementNumber": 10,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(10,1,0,0,255,0) glp(10,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,6,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
            "controlElementNumber": 11,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(11,1,0,0,255,0) glp(11,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,7,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
            "controlElementNumber": 12,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(12,1,0,0,255,0) glp(12,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,0,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
            "controlElementNumber": 13,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(13,1,0,0,255,0) glp(13,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,1,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
            "controlElementNumber": 14,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(14,1,0,0,255,0) glp(14,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,2,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
            "controlElementNumber": 15,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] glc(15,1,0,0,255,0) glp(15,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@cb]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128 gms(ch,144,3,val) glp(num,1,val+30) toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@cb]] colors={\"blue\", \"blue\", \"red\"} function toggleColors(buttonIndex)glc(buttonIndex,1,255,0,0,0)for i=0,15 do if i~=buttonIndex then glc(i,1,0,0,255,0)end end end ?>"
                    "event": 4,
                    "config": "<?lua --[[@cb]] gpl(gpp()) ?>"
                    "event": 5,
                    "config": "<?lua --[[@cb]] local ch,cmd,param1,param2=midi.ch,midi.cmd,midi.p1,midi.p2 ?>"
                    "event": 6,
    "cloudId": "yynfPARcBu5jeieUmgkG",
Ok, I figured out I can use the code option here and copy the text of those *.json files in. These are the configs that cause a lot of errors, although both of them work individually without any problems.
In case the non-coded version is preferable to figure out:
    "id": "97596069-51b4-446a-b276-03e0b1b45bb4",
    "modifiedAt": "2024-04-05T01:56:48.567Z",
    "name": "Cubase Controller EF 44 page 1",
    "description": "This Controller causes problems when connected together with ",
    "type": "EF44",
    "version": {
        "major": "1",
        "minor": "2",
        "patch": "51"
    "configs": [
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@sec]] self:emo(2) self:ev0(90)--[[@sbc]] self:bmo(1)--[[@cb]] self:bmi(0)self:bma(1)--[[@glc]] glc(0,1,255,0,0,0)--[[@glp]] glp(0,1,1) ?>"
                    "event": 3,
                    "event": 2,
                    "config": "<?lua --[[@l]] local val,Enc1cc=self:eva(),12--[[@cb]] if bank==1 then Enc1cc=12 elseif bank==2 then Enc1cc=16 end--[[@gms]] gms(0,176,Enc1cc,val) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@sec]] self:emo(2) self:ev0(90)--[[@sbc]] self:bmo(1)--[[@cb]] self:bmi(0)self:bma(1)--[[@s]] self.enc1cc=13--[[@glc]] glc(1,1,0,190,255,1) ?>"
                    "event": 3,
                    "config": "<?lua --[[@bpr]] if self:bst()>0 then--[[@gms]] gms(0,144,0,127)--[[@bprel]] else--[[@gms]] gms(0,144,0,0)--[[@bpre]] end ?>"
                    "event": 2,
                    "config": "<?lua --[[@l]] local val,Enc1cc=self:eva(),12--[[@cb]] if bank==1 then Enc2cc=13 elseif bank==2 then Enc2cc=17 end--[[@gms]] gms(0,176,Enc2cc,val) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@sec]] self:emo(2) self:ev0(90)--[[@sbc]] self:bmo(1)--[[@cb]] self:bmi(0)self:bma(1)--[[@s]] self.enc1cc=14--[[@glc]] glc(2,1,255,204,0,1) ?>"
                    "event": 3,
                    "config": "<?lua --[[@bpr]] if self:bst()>0 then--[[@gms]] gms(0,144,1,127)--[[@bprel]] else--[[@gms]] gms(0,144,1,0)--[[@bpre]] end ?>"
                    "event": 2,
                    "config": "<?lua --[[@l]] local val,Enc1cc=self:eva(),12--[[@cb]] if bank==1 then Enc3cc=14 elseif bank==2 then Enc3cc=18 end--[[@gms]] gms(0,176,Enc3cc,val) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@sec]] self:emo(2) self:ev0(90)--[[@sbc]] self:bmo(1)--[[@cb]] self:bmi(0)self:bma(1)--[[@s]] self.enc1cc=15--[[@glc]] glc(3,1,255,8,26,1) ?>"
                    "event": 3,
                    "config": "<?lua --[[@bpr]] if self:bst()>0 then--[[@gms]] gms(0,144,2,127)--[[@bprel]] else--[[@gms]] gms(0,144,2,0)--[[@bpre]] end ?>"
                    "event": 2,
                    "config": "<?lua --[[@l]] local val,Enc1cc=self:eva(),15--[[@cb]] if bank==1 then Enc4cc=15 elseif bank==2 then Enc4cc=19 end--[[@gms]] gms(0,176,Enc4cc,val) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@l]] local val=self:pva()--[[@glc]] glc(4,1,102,255,0,0)--[[@glp]] glp(4,1,val) ?>"
                    "event": 1,
                    "config": "<?lua --[[@l]] local val,Fad1cc=self:pva(),4--[[@cb]] if bank==1 then Fad1cc=4 elseif bank==2 then Fad1cc=5 end--[[@gms]] gms(ch,176,Fad1cc,val)--[[@glp]] glp(4,1,val) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@l]] local val=self:pva()--[[@glc]] glc(5,1,255,214,0,0)--[[@glp]] glp(5,1,val+1) ?>"
                    "event": 1,
                    "config": "<?lua --[[@l]] local val,Fad1cc=self:pva(),4--[[@cb]] if bank==1 then Fad2cc=3 elseif bank==2 then Fad2cc=6 end--[[@gms]] gms(0,176,Fad2cc,val)--[[@glp]] glp(5,1,val) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@l]] local val=self:pva()--[[@glc]] glc(6,1,255,0,0,0)--[[@glp]] glp(6,1,val+1) ?>"
                    "event": 1,
                    "config": "<?lua --[[@l]] local val,Fad3cc=self:pva(),11--[[@cb]] if bank==1 then Fad3cc=11 elseif bank==2 then Fad3cc=7 end--[[@gms]] gms(0,176,Fad3cc,val)--[[@glp]] glp(6,1,val) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@l]] local val=self:pva()--[[@glc]] glc(7,1,255,104,0,0)--[[@glp]] glp(7,1,val+1) ?>"
                    "event": 1,
                    "config": "<?lua --[[@l]] local val,Fad4cc=self:pva(),1--[[@cb]] if bank==1 then Fad4cc=1 elseif bank==2 then Fad4cc=8 end--[[@gms]] gms(0,176,Fad4cc,val)--[[@glp]] glp(7,1,val) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@g]] bank=1 ?>"
                    "event": 4,
                    "event": 5,
                    "config": "<?lua --[[@l]] local ch,cmd,par1,par2,i=midi.ch,midi.cmd,midi.p1,midi.p2,1--[[@cb]] if cmd==144 or 128 then if par1==0 then glp(1,1,par2)elseif par1==1 then glp(2,1,par2)elseif par1==2 then glp(3,1,par2)end end ?>"
                    "event": 6,
    "fileName": "Cubase Controller EF 44 page 1 2.json",
    "isEditable": true,
    "syncStatus": "local"
    "id": "422d0d58-7120-40dc-88d7-fb1beb133a37",
    "modifiedAt": "2024-04-05T01:58:03.600Z",
    "name": "Cubase Controller BU16",
    "description": "This Controller cuases problems when connected together with Cubase Controller BU16.",
    "type": "BU16",
    "version": {
        "major": "1",
        "minor": "2",
        "patch": "51"
    "configs": [
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(0,1,0,0,255,0)--[[@glp]] glp(0,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,12,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(1,1,0,0,255,0)--[[@glp]] glp(1,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,13,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(2,1,0,0,255,0)--[[@glp]] glp(2,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,14,val)--[[@glp]] glp(num,1,val)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(3,1,0,0,255,0)--[[@glp]] glp(3,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,15,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(4,1,0,0,255,0)--[[@glp]] glp(4,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,8,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(5,1,0,0,255,0)--[[@glp]] glp(5,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,9,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(6,1,0,0,255,0)--[[@glp]] glp(6,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,10,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(7,1,0,0,255,0)--[[@glp]] glp(7,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,11,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(8,1,0,0,255,0)--[[@glp]] glp(8,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,4,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(9,1,0,0,255,0)--[[@glp]] glp(9,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,5,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(10,1,0,0,255,0)--[[@glp]] glp(10,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,6,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(11,1,0,0,255,0)--[[@glp]] glp(11,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,7,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(12,1,0,0,255,0)--[[@glp]] glp(12,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,0,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(13,1,0,0,255,0)--[[@glp]] glp(13,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,1,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(14,1,0,0,255,0)--[[@glp]] glp(14,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,2,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@glc]] glc(15,1,0,0,255,0)--[[@glp]] glp(15,1,20) ?>"
                    "event": 3,
                    "config": "<?lua --[[@l]] local num,val,ch,note=self:ind(),self:bva(),(gmy()*4+gpc())%16,(32+gmx()*16+self:ind())%128--[[@gms]] gms(ch,144,3,val)--[[@glp]] glp(num,1,val+30)--[[@cb]] toggleColors(num) ?>"
                    "event": 6,
            "events": [
                    "event": 0,
                    "config": "<?lua --[[@g]] colors={\"blue\", \"blue\", \"red\"}--[[@cb]] function toggleColors(buttonIndex)glc(buttonIndex,1,255,0,0,0)for i=0,15 do if i~=buttonIndex then glc(i,1,0,0,255,0)end end end ?>"
                    "event": 4,
                    "event": 5,
                    "config": "<?lua --[[@l]] local ch,cmd,param1,param2=midi.ch,midi.cmd,midi.p1,midi.p2 ?>"
                    "event": 6,
    "fileName": "Cubase Controller BU16 2.json",
    "isEditable": true,
And here some explanation what these are supposed to do:
the button unit is a simple key-switch unit for sample libraries. The buttons should light up blue and the one you pressed last is red.
The Fader unit is supposed to have four simple midi CC-faders with different colors and selected CC-values. The encoders are relative encoders for the quick control system in Cubase. The first push encoder is switching the encoders to bank 2 (QC 5-8) and the faders get different colors and CC-values. The other push encoders get functions via midi remote in Cubase and receive feedback from those functions (change color accordingly).
All of this works, but most of the time I connect both controllers, it is a mess!
