Hi all,
I’m trying to send hi res values using the faders, it looks they can handle 10 bit range (0-1023) and i would like to create a pitch wheel output using this value.
I don’t see any straigh forward way to create pitch whell values in the Midi 14 bits tab, so i’m using the regular Midi message tab with a command = 224 (Pitch on channel 0)
I’m not familiar with Lua, but other languages.
My very first try is:
num = self:potmeter_value()/8
val = self:potmeter_value()%128
but the num doesn’t work as expected.
Any tip?
