Is possible to have 16 setups with EN16?
Hi there,
So the point of profiles and pre-made configurations is that they have everything the developer put in there for you to use possibly extending the features of the base configuration in ways not normally possible for the average user.
It also has a big downside because of this, they are very hard to customize for the everyday user.
In this case however I could easily create a relative mode version of the 64CTRL or a setting in the profile itself to let you easily switch between the two versions.
Would this be something that you guys would be interested in?
I’m not sure what is happen, but I used 64CTRL 2.2 and in midi monitor it was ok. Then I have changed CH to 9 for all encoders - and it’s fine. Then I have updated the code for encoders CCs in config 1, but EN3 (cc 38 in configuration in code) had problem - instead of CC it sent strange values (last column - according to midi monitor). When I changed CC number to other random values - it works as expected.
And it was happen to second EN16 too, the same CH9, for EN3 (cc 98) - but this time it sent NPRN messages (according to midi monitor). I did not check if it sent correct values to the devices, only midi monitor was used.
PS. I have checked it with other MIDI monitor - i think this problem comes from grid midi monitor.
And one more strange thing - CCs in code are the same in external midi monitor, but channel numbers are wrong - in CH configuration (in times) is 9, internal midi monitor shows 9, but external shows 10.
Sadly MIDI monitor is bugged!
A known issue you can check here, it should be fixed in 1.3.9!
I also made the switch to enable relative encoders @user132 , but in my testing it defeats the purpose of the controller as the displayed values and the LEDs on the EN16 will not be able to stay in sync like this.
If you would still like to test drive the profile, let me know!
Hello @narayb,
I am looking to use this type of setup but with a bit more customization. I am looking for where I can learn how the code functions and how you go about storing “Banks”. I want to do the banking function but also to add banks to certain rows individually as well as color stuff. for example…on an 8 freq graphic eq use the right knob to “page up” to get another 4 knobs on the row and the left knob to “page down” back to the first row.
I really liked your template. I made a remix called 256CTRL
This provides 16 banks with a defauilt color spread
CC can be defined or defaulted.
Midi Channels are assigned sequentially based on banks.
Desync and ABCD feaures untested.
Wow, really nice remix. Thank you for sharing.
(I checked and desync works properly as well. CTRLALL was always wonky, I was working on reworking it.)
Kind of Necroposting? Is there no longer a website where I can see profile cloud uploads?
I revised the 256CTRL profile that I made (forked from 64) a while ago.
  1. Custom colors in a few fun ways.
  2. MidiRx support for active and saved bank values. (tested in LoopyPro)
  3. Cleaned up some code and removed the ABCD and Desync for now.
grid-editor://?config-link=3PyGKV8y4uSZJysv4VUu
Try to break it? I’m sure I’ve messed something up.
This is insane work, thank you for the contribution!
I tested the MIDIRX section myself in Ableton and it works really well there too!
ABCD was a bit of an experiment anyways, but desync is a concept I might just hack back into your version :p.
What did you mean by Is there no longer a website where I can see profile cloud uploads? I could find yours in the Cloud swiftly in Editor.
Do you mean the old website over at intech.studio/cloud or wherever it was?
Ty! Yeah it was cool to see the ticker of what folks were working on the web. Glad you found it in editor!
Yeah, I thought about the desync for other devices, but I only have this one module so this was a bit of a selfish build. If you manage to get it back in, I’m sure others would benefit. I really just wanted to make rx worked and I needed a way to set persistent custom colors in one place. That was the main goal at the start.
Might have gotten a little carried away with the colors palettes lol.
Just checked and https://profiles.intech.studio/ is still alive, there’s just no link for it on the site currently!
The palettes with the built-in color palette tweaking solutions is genius.
It’s really inspiring to see users create so much more than we could think of with the tools we made.
Makes me want to finish the article about writing into file on Grid…
I also wanted to say that we have an update coming to how MIDIRX behaves next FW release.
I’ll create a writeup here and on the docs about it. It’s not a huge deal, but it does make the current behavior legacy. Sorry.
Thanks! It’s actually pretty fun to code on. I’m sure whatever changes with RX, we can make it work. Getting that working like it’s now in the recent update was a HUGE boon.
Hello :slight_smile:
I’m new to this, so I hope I’ve found the right thread.
I’ve bought 1 mechanical button and 1 detent v3 encoder.
I want to have every button switch to a set bank on the encoder. So I have 16 banks with 16 encoders.
Can anybody guide me in the right direction? Is there already a script for this?
Thank you very much.
There is a really nice profile called 256CTRL you can use to achieve exactly this! Search for its name in the Profile Cloud and you should be able to find it.
Hiya,
I checked your code and it seems it was never updated to the new paradigm of MIDIRX.
I did the update though! How can I send it to you?
edit: Posted it under 256CTRL - MIDIRX Fix on the cloud, whenever you get to updating the original, I will take this one down!
Hrm. Maybe I accidentally l loaded the wrong version back up to the cloud…. Let me see, I def had it working after the update cause I had to fix the element init issue.
@narayb late with the update, but thank you for the fix! I encorporated it and republished here. 256CTRL v2.1
I’ve been on a journey of building other things, but have a new project coming up and I needed the trusty EN16 again.
Happy knob turning!
