LR Console: a six-module Grid controller for Lightroom Classic (open source, built with AI)
Over the last couple of months I’ve built a six-module Grid controller for Lightroom Classic. It’s now how I edit. The video shows a full edit, start to finish, with the mouse used only to draw two masks, set the crop, and drag one slider on purpose to show the board following.
Everything is on GitHub. Link below. That’s the Lightroom plugin fork, the Python that generates the Grid configs, my 16 profiles and the working notes.
What it does
  • One jog wheel drives whichever slider is selected. Turn for coarse, hold and turn for fine, tap to undo the turn, hold to reset.
  • The board follows Lightroom, not just the other way round. Drag a slider with the mouse and the board selects it. Open a mask and the same keys drive the mask’s sliders. Enter Crop and the jog straightens. Label and flag keys light up when the photo carries that label or flag.
  • The screen shows the real value from Lightroom, live.
  • The Colour Mixer (all eight bands, H/S/L) is always on two EN16s, plus one-press split-tone presets.
  • Culling, labels, views, Crop, Mask, Before/After, Copy/Paste and Undo/Redo are on fixed keys that never change with the page.
The AI part, up front. I designed the layout, assembled the hardware and tested every change on the board while editing real photos. Almost all of the code was written by Claude (Anthropic’s AI) in conversation with me. I didn’t write the Python. It was a genuine collaboration, and it was often wrong. The repo’s notes mark every claim as measured, read from source or assumed, because we learned not to trust anything that hadn’t been tested on the board. More on that below.
Most reusable part: the plugin fork. It works with any Grid layout and gives the board readback from Lightroom: values, current module and tool, label, flag, and slider follow.
Replies below cover:
  1. Why I built it, and how it came together
  2. How it works in use
  3. The code, the plugin fork, and what we learned about the Grid that isn’t in the docs
Github Link: GitHub - cjselbyspink/lr-console · GitHub
Post 2 — why, and how it came together
Why. I’ve been photographing for about twenty years. I hold an LRPS and I’m about to submit for ARPS. I went from a DSLR to phone-only 10-15 years ago, got fed up with phone processing, and in the last year or two came back to proper cameras: a Sigma BF and a Leica SL3 with Sigma lenses. That meant learning Lightroom properly, which I’ve done over the last six months. I’d seen closed, off-the-shelf editing consoles on Instagram and thought an open, modular one could do better. That’s how I found Intech.
How it came together
  1. Three modules (August). VSN1, EN16 and TEK2. I started from Intech’s own Lightroom package and Intech’s “1 Knob 8 Function” profile for the VSN1 from the Profile Cloud (one wheel, eight keys choosing what it drives), which the Lightroom package docs recommend, and built a multi-page unit from there.
  2. Six modules. I added a second EN16, a BU16 and a VSN2, mounted on a 3 mm Dibond plate with Dual Lock. I also rethought the design: rather than four equal pages, it’s essentially one main page I spend most of my time on, plus a Tone page.
  3. No more pasting code into the Editor. Each event script is capped at 908 characters, and pasted code drifts from what you think is on the module. Instead, Python generates the profile .json files, checks every event against the limit, and stamps each build so the Editor’s cloud copy can’t quietly shadow it. I import them directly. Rebuilt from the published code, the generator reproduces every script on my board exactly.
  4. Working round the hardware. Several things we needed aren’t in the docs or don’t behave as the docs suggest. For example, only VSN modules receive eventrx_cb, so TEK2 and BU16 talk to VSN1 over MIDI CCs instead. Details are in my code post.
  5. Forking the plugin. This was the big one. The stock plugin takes commands and returns EXIF. The fork returns state: the live value of the slider you’re turning, the module and tool (so mask mode and the crop jog follow Lightroom), the label and flag, and the slider you just dragged with the mouse. That’s what turned it from a remote control into something I can edit by.
  6. Redesign from real use. I edited a full wedding set on the first version and counted what I actually reached for. Mask Exposure, Highlights and Saturation were by far the most-used controls, yet they sat behind a page flip. Page switching (1–2 s and a full-board flash) was the main annoyance, and two of the four pages were barely used. The current layout came out of those counts.
What went wrong along the way (in the interests of honesty)
  • Hardware: one BU16 edge was dead, which turned out to be an oversized spacer, and one EN16 was unreliable as the USB host. Intech support were helpful with both. VSN1 is now the host.
  • A bricked module: an early immediate_send experiment locked up a module badly enough to need a factory reset. We haven’t used it since.
  • AI misdiagnosis: the AI blamed hardware for code problems more than once. The worst was TEK2’s “broken” eventrx_cb, which is simply a VSN-only feature. A test that would have shown it was available from day one.
  • Fixes that never shipped: some fixes failed silently at the patch stage and went out unapplied, one for a week. Now the generated output is checked, not the patch.
  • Stale plugin code: “Reload Plug-in” in Lightroom leaves the old instance answering on the port. That caused two false bug reports.
Time and cost. I ordered the first three modules on 9 August and the second three on 20 August. It reached its current shape in early October, with tuning until late October. Most of that was evenings, while on parental leave with two small children. The six modules list at about £914 before tax on Intech’s shop. I paid about £1,070 in all, including UK VAT, shipping and extra keycaps, plus the Dibond plate and Dual Lock.
Who did what. I did the design, the hardware, all the testing and every decision about how it should feel. Claude wrote the code and the plugin changes, read the Lightroom SDK and Intech’s source, and kept the notes. It was very good at reading source, and at finding a bug in the plugin log in minutes once we started reading the log. It was poor at knowing when it was guessing. The marking scheme in the docs exists because of that.
Post 3 — how it works in use
The plate, far row first:
VSN2  (upright)   EN16-A (270°)   VSN1  (USB host)
TEK2  (180°)      EN16-B (270°)   BU16  (upright)
Left hand: decisions and views (fixed on every page). VSN2’s keys are Reject, Pick, the five colour labels and Clear. Each label key lights fully only when the photo carries that label. TEK2’s keys are Crop, Library, Develop, Survey, Mask, Before/After (hold), Copy and Paste. Crop and Mask light up whenever Lightroom is in that tool, however you got there. TEK2’s dials are Zoom and Filmstrip. VSN2’s small buttons are stars 1–3, Auto WB, Reference, Compare, Auto Tone and Clipping.
Middle: colour. The two EN16s give Hue, Saturation and Luminance for all eight bands, all the time. 5 per detent, 1 while held, and a tap resets the band. The fourth column holds split-tone presets: press to apply, spin to scale the strength. The band and value flash up on VSN1’s screen.
Right hand: the jog and the sixteen. The 4×4 keys under the jog (VSN1’s eight plus BU16’s top two rows) choose what the jog drives. On page 1 that’s Temp, Tint, Exposure, Contrast, Highlights, Shadows, Whites, Blacks, Texture, Clarity, Dehaze, Vibrance, Saturation, Vignette, a spare, and Reset.
  • Turn: coarse, in steps of 5 (Exposure in 0.05).
  • Hold and turn: fine.
  • Tap: back to where this turn started.
  • Hold 0.6 s and release: Adobe’s default.
BU16’s bottom rows are Undo, Redo, Prev, Next, Map (hold it and the screens show every key), a key that brings Lightroom to the front, and the crop aspect and overlay keys, which only light while Crop is up.
The board follows Lightroom.
  • Masks: make a mask with the mouse and the board switches to mask mode within about 0.3 s, lands on Exposure, and the same sixteen keys now drive that mask’s sliders (Vibrance becomes mask Hue). An Invert Mask key appears. Leave the mask and it goes back.
  • Slider follow: drag any slider with the mouse and the board selects it, so the jog takes over from where your hand left off.
  • Crop: in Crop, the jog straightens; tap to zero.
  • Readout: the VSN1 screen shows the selected parameter and the value Lightroom reports, up to 20 times a second. A small reply counter in the corner means a stale value can’t pass for a resting one.
  • Lightroom also opens the panel of whatever slider the board moves.
Pages. Page 1 is Develop. Page 2 is Tone: the parametric curve on the jog, and colour grading with TEK2’s dials as Hue and Sat of a zone chosen by TEK2’s keys. Page 3 is Detail: sharpening, noise, vignette and grain. Page 4 is spare. Changing page takes 1–2 s and flashes the whole board, which is why the layout keeps almost everything on page 1.
What it doesn’t do. Mask Amount has no working SDK parameter, so it isn’t on the board. I’ve only run it on a Mac. Windows should need two small changes (Ctrl in place of Cmd on a few shortcut keys, and a different helper for the key that brings Lightroom to the front), but that’s untested.
Post 4 — the code, the plugin, and what isn’t in the docs
How the pieces connect. The board talks to Intech’s Lightroom package in Grid Editor (stock, unchanged), which talks to a Lightroom plugin on port 23111. I replaced the plugin with a fork; the stock one stays installed but disabled. Replies come back as a call to LrImportActive(...) on every module.
The plugin fork (plugin/) is the part anyone can use. It adds:
  • State in every reply: module (L/D, plus C for Crop and M for Masking), colour label, rating, flag.
  • Value echoes: up to 20 a second while a slider turns, with the final value always sent.
  • Slider follow: 58 parameters polled at 5 Hz in Develop, so a mouse drag is reported.
  • A watcher: every 0.3 s, so changes made with the mouse or keyboard reach the board.
  • New commands: revert-param, reset-param, color-toggle, tool-toggle, a one-message split-tone preset, and a Library key that toggles Grid and Loupe.
  • Hue wrap on the four 0–360 sliders, and revealAdjustedControls.
The fork reuses the stock reply’s EXIF fields to carry all this, because the package only relays named fields. It’s a hack, but it means index.js didn’t need forking.
The generator (generator/) is plain Python 3. It writes readable Lua, minifies it, swaps in the device’s short names, checks every event against the 908-character limit, and writes profiles with the wrapper copied from your own Default exports. It also runs lint for the mistakes we actually made. To change a key, you change a list in lr_pages2.py and rebuild.
Things we learned the hard way. All are measured on hardware; evidence is in docs/CODE-REFERENCE.md.
  • The package delivers one develop message per 50 ms and drops the rest. This caused the “spinning faster covers less” effect: a fast spin delivered a sixth of a slow one. Batch your sends: we send every sixth dial event, with the remainder carried over.
  • eventrx_cb fires only on VSN-family modules. TEK2 and EN16 never receive it. midi_send → midirx_cb reaches every module; header[1] == 14 marks module-to-module traffic.
  • Only one package_send per event reaches Lightroom; the last one wins. Spread several sends across timer ticks. Note that timer_start is one-shot.
  • endless_state() - 64 is a velocity sampled at about 110 Hz. One revolution sums to about 91,000 at any speed. The occasional spike should be replaced with the previous reading, not dropped.
  • LEDs: layer -1 silently does nothing, led_value only gates the LED on and off, and the alpha in led_color is the brightness.
  • Grid Editor does not remap element numbers for rotated modules, so the code has to.
  • The Editor’s cloud copy shadows a local profile with the same name and id. Put a build stamp in the name.
  • After every plugin change, restart Lightroom; reload isn’t enough.
To Intech: thank you for a platform that rewards this much digging. The fork is derived from your plugin. Its package.json says ISC and the repo has no LICENSE file, so I’ve kept your notice and credited the original. If you’d rather it were handled differently, tell me. Some of the plugin changes might be worth taking upstream, particularly the value echo and the 50 ms drain finding, and I’m happy to help with that.
Questions are welcome here. It’s offered as-is: I’ll answer what I can, but this is a hobby project.
