MIDI Rx - how to?
New user here with some decent programming skills.
Can anyone help me figuring out how to get the Midi Rx to function?
I want to use an EN16 and PU16 to (midi)control my DAWfunctions (Cubase).
Assigning CC’s and stuff is easy but getting the info from the DAW back into the controllers is where I’m getting grey hairs.
Basically: Inside my DAW I have switches assigned to bypass insert plugins on the selected channel. If I press for instance button 1 then I can bypass/enable the insert#1 on the selected channel (and the led goes bright).
But when I switch channels I don’t get the midi to send back to the controllers. In other words:
Ch1 Insert1 is disabled, Ch2 Ins is enabled. How do I get the MidiRx function to interpret the data that Cubase is sending back??
Basically: I can’t find where in the manual I can find the different properties of every assignable knob/button/encoder/fader so that I could write a code block for midirx.
Also: why isn’t receiving midi messages for every sending item a standard thing?That would eliminate the need for a lot of coding I would guess.
Thanks in advance,
Herwig
Still searching… when clearing whatever I already did and enabling debug view in the midi monitor window I’m getting this message when I touch something in my DAW:
[0,0] LUA not OK! EL: 16 EV: 5 MSG: [string “ele[16.mrx = function (self) --[[@l]] local …”]:1: attempt to index a nil value (field ‘?’)
I’ve looked at this phrase for 10 minutes now and tried googling and copilot-ing stuff but can’t find anything :man_shrugging::man_shrugging:
I’ll give this 2 more days until I send the units back - receiving midi messages on a midi controller should be not this hard IMO.
Herwig
I think I have the same issue. This page pretty much tells us how to set up receiving midi messages, but even the exact code given in the example yields the same error.
https://docs.intech.studio/wiki/events/system-events/midirx-event/
