PFB4 pot not working correctly with daw (Reaper)
I’ve gotten all my EF44 and PFB4 assigned except the pots on the PFB4. I’ve tried multiple forums and attempts to link the pots for panning, but every time it just goes hard left/right. The only code i found to work is the Fader code for the EF44 assigned to the pot of the PFB4, which is insufficient as i use that alongside.
Insids the grid editor, my pots work fine (1 -127)
Inside Reaper, the only values are 0 or 100 (L or R)
The %128val code worked for some reason, but i cant get it to work without overriding the other
Obviously not a coder, plz help
