I am looking for a way to check if an element is generating events. It would be in a similar vein as event_trigger() function in that you’re interacting with a physical component without actually moving it.
event_status(element) would return the state of an element to see if it is generating events or not (idle). I don’t want the value being returned just the state.
My issue is that, when I use a Grid encoder to change the value of a parameter on a hardware device, that device sends the change back out. I am using midi_rx to have the encoder’s value stay in sync. The problem is that it gets wonky because of the feedback.
If I could check to see if an element is idle or generating events, I could have midi_rx ignore those incoming values.
In simpler terms:
IF encoder is generating events then, midi_rx does not translate/update values. ELSE translate/update values.
Without this type of function, is there another way to achieve this? The device cannot be set to only send data when locally updated. It just sends its values whenever they are changed regardless of the source.
EDIT: Thinking this through a little further, could a timer be set when an element generates an event (I’m sure it can)? If the timer is running, ignore incoming MIDI messages for that element. Something to that effect.
