VCV Rack + PO16 + Intel Mac = crashes allways
Hey Guys,
I bought a PO16 controller to use it with VCV Rack 2 and faced a serious problem with VCV rack constantly crashing.
Configuration:
  • Intech PO16 via USB C connected
  • VCV Rack 2.5 or also 2.4.1 testet
  • VCV Rack default patch
  • Intel Mac Book Pro 16 Zoll 2019 mit Intel core i7
VCV Rack crashes immediately after connecting the PO16, independent of the patch loaded. Connecting the PO16 to the Mac when VCV Rack runs lead to the same crash. The PO16 is working on the Mac in general in other software or MIDI monitoring tools. Interestingly connecting the PO16 to another Mac and using the MIDI tools of the Mac over a network session allows to use the PO16 in VCV rack. Using it over another Mac is possible but very unusable for me.
Does anybody experience the same or even have an idea how to solve it?
Thanks a lot!,
Stephen
It is currently a known issue that VCV crashes with Grid. We have reported it personally to VCV and they have confirmed the bug and are currently working on it. Our last contact has been more than a month ago now, I will send them a message to get and update about this fix.
Sadly they have no public platform where you could follow their progress on bug, otherwise I would link it here.
Will report back!
Hi @user107 !
Here’s what I got after checking back with VCV support about our inquiry:
We have recently had a couple users who report that enabling ‘Input Monitoring’ security access for the VCV Rack app in macOS system settings resolves the issue for them. We have asked several other users who reported the problem in the past few months to try this and are awaiting their responses before concluding that this does indeed resolve the issue. If you could try it and let us know if it works there, it would be appreciated.
If you could try this solution and see if it helps you, it would be valuable feedback to us and them, but aside from this, I have no updates.
I’m curious to see if this resolves the issue.
I am running into the same issue, running the current firmware on my Grid controllers. I’ve enabled Input Monitoring for VCV Rack 2 Pro and it still crashes upon launch… so no, this does not resolve the issue… but good thought.
I also reached out to their support team today and have been sharing crash logs with them. I’m happy to share them with Intech or make a connection as well.
Thanks!
Interesting. In our testing a couple of months ago, all crashing issues were solved by the above workaround.
We’ll test this out again soon to see what could have happened.
Which version of VCV Rack did you experience this?
After I enabled input monitoring for VCV, ESP-32 variant units I have at hand don’t crash on VCV Rack Pro 2.5.2, I’m on M1 mac, running the arm version.
I’m currently running…
VCV Rack 2 Pro, 2.5.2
MacOS 15.2 with latest patches
MacBook Pro, 16-in, 2019, Intel Core i9 (which may have a different USB controller than Apple M based systems)
Grid Editor 1.3.8, E-32 blocks v1.2.39
I’ve also tried the following “refresh” with no luck:
  1. Disable Input Monitoring for VCV
  2. Delete VCV App & app support files
  3. Empty trash
  4. Reboot
  5. Reinstall VCV
  6. Enable Input Monitoring
  7. Connect single block directly via USB-C to USB-C as ONLY peripheral connected.
  8. Attempt to launch VCV
    … CRASH
VCV 2 Pro does still work as a plug-in, so there’s a way around it… but certainly not ideal. I’ve also tried other settings like full-disk access, but still no luck.
FYI, this still happen on a Mac Mini M4 running last Sequoia version, with EF44 and VCV 2.6.2.
Adding input monitoring permission did work for me, though.
