I am using buttons on the VSN1 to setup Midi CC functions on the wheel.
E.g. my DAW is setup to have Ch 10 as control channel, and Tempo as controller 30, while sending a command on CC 19 makes it resend all current controller settings.
Registered global variable wheel_cc on Element 14 (System)
Button 0 push:
wheel_cc = 30
event_trigger(8, 0)
midi_send(9, 176, 19, 1)
Element 8 Setup:
self.cc = wheel_cc
Element 8 Endless:
Self variable cc = wheel_cc
Midi Parameter 1: self.cc
Midi sync value and sync LED selected
Endless mode 0
There are other buttons that set the wheel_cc to other parameters.
This works to assign a custom cc value by button press.
But it does not update the MidiRx cc value until the wheel is moved, thereby sending the last value (from a potentially different previous button cc parameter) to the DAW. E.g. arpeggiator gate might have last sent value 30 to the DAW, and then pressing button 0 to change the tempo it sends 30 first when the wheel is moved.
I am out of ideas on how to set the initial value automatically. The DAW resends all values at Button 0 push as requested through the midi_send (I checked that works, since other push buttons update), but the MidiRx for the wheel appears to update only when the wheel is moved.
How can I fix this, I assume I’m not the first person with this problem.
There is a post about assigning Midi CC for the Wheel via button press, but this does not address the initial value problem:
Please don’t reference Discord, I don’t do Discord.
Any ideas are appreciated!
